Hi all
got a whine coming from the transfer box. Had it up on the ramp today can hear it in the cabin but nothing when under it with the wheels going. Had to get a stethoscope to hear it and it's coming from the transfer box/case . Pulled the oil plug and was over filled with oil... But it did have flecks of metal in it so I'm thinking the bearing is on its way out.
Question is can I use any secondhand transfer box off any manual e83? Or does it have to be a one from the exact same engine/year/manual?
Cheers any help welcome
E83 transfer box 2007 2.0d manual
Re: E83 transfer box 2007 2.0d manual
Put the last 7 of your VIN into RealOEM (on line BMW parts database) under Serial Number and it will bring up your model. If you then pull up the transfer case (press the part number link and it shows what uses that part)and see which models it can be used on that should tell you. It should be an ATC400 and they are used across all E83 xDrive versions.
As an aside, do you have a staggered wheel size or square (identical) setup on the car?
What tyres do you have fitted and are they the correct ‘*’ marked type? Do they also have less than 1.5mm tread depth difference between any one tyre and any other? E83s are very sensitive to tyre type and having the wrong ones (ie not ‘*’ marked) or a greater tread depth can and does cause broken transfer boxes.
This is very important on cars with a staggered set up, however one tyre with more wear than others can just as easily cause the same problem. A second hand ATC400 could have the same issue. Something to be aware of.
mwain6969
Thanks for that
I haven't had it long but it's got pirelli scorpion verde 235/50r18 97h all round. Look pretty new and look like they went on as a set
Your right it is the ATC400 for mine arcording to the part checker.
I know what you what you are saying about the transfer box. I've priced up reconditioning at £750, but can get a transfer box from a bmw breaker for £150 and fitted £100 so it's a bit of risk and reward I suppose
