Auto locking of doors when driving away from standstill
X5-D-Sport
I have gotten a replacement X5 recently, lots if issues to fix.
My previous E53 diesel would lock its doors shortly after driving away after getting in..
this car won't do that, it only locks when the button is pressed on the centre console.
Is there a sequence of operations or button presses or some thing to enable the Auto-Door-Lock feature when the car starts moving.
I have looked on You-Tube, but am possibly using the wrong search words,
regards to all
regards to all
Re: Auto locking of doors when driving away from standstill
Somebody must have turned the function off.
It needs coding back in with carly or some other coding.
It is a coding function normally done by a Dealer at delivery. As above you’ll need someone to code it for you, or use Carly (or similar).
Bmwxfan
Have you checked the idrive ? On my E70 and E60 you can enable and disable the auto door locking from the idrive menu.
X5-D-Sport
re-i-drive.....
I dont think the E53 has that option
It doesn’t
I’ve coded this on the replacement beast using scanner 1.4.0
Pretty straight forward and at the same time added the lock/unlock bleep.
It’s only a coding option so can’t be set using the key in any sequence etc.
X5-D-Sport
Hi Raj,
hope you are well Sir..
I think my fault scanner is a 1.4 some thing.... it lives in the vehicle, so I will have a tinker & se what I can do.
many thanks for the suggestion.
regards
Grant B
regards
Grant B
All good here buddy. Hope you’re well too during this current time.X5-D-Sport Salisbury wrote: Sat Nov 21, 2020 5:14 pm Hi Raj,
regards
Grant B
If you need and help let us know.
