				Rear diff and transfer box oil change
				Posted: Thu Nov 12, 2020 6:48 am
				by Roryb1985
				Good morning all. I want to change the oil on both rear diff and the transfer box when I do my engine oil change next. Question is what oil do I need for the diff and transfer box  thanks
				Re: Rear diff and transfer box oil change
				Posted: Thu Nov 12, 2020 7:39 am
				by Alan Gunn
				Just the correct oil.
Easy job to do.
				Posted: Thu Nov 12, 2020 8:14 am
				by Roryb1985
				Thanks Alan. But I’m asking what is the correct oil for this job
				Posted: Thu Nov 12, 2020 8:26 am
				by Alan Gunn
				Posted: Thu Nov 12, 2020 11:47 am
				Posted: Thu Nov 12, 2020 11:07 pm
				by Raj
				Just get it from the dealers as you don’t need a huge amount and best to get their own to be 100% correct. That’s what I did but was many years ago.
				Posted: Thu Nov 12, 2020 11:18 pm
				by sleepyfolk
				I’d second Raj, when I did some bits to mine I got all the bits from Cotswold BMW and the prices are cheap anyway so you may as well get if from them, even the seals etc were cheap which surprised me
TRANSFER CASE
Oil BMW ATF DIII	83229407858	                1 Litre.             	£14.69
Screw Plug (fill and drain)	27111226467	2			         £19.44
Gasket Ring	7119963308	                                2			         £1.13
REAR DIFFERENTIAL
Oil BMW Synthetik OSP	83222365987        	2 Litres	        £57.61
Screw Plug (fill and drain plugs) 33117525064	2		        £7.88
Gasket Ring	07119963355	                                2			£0.86
Dust Guard Ring Outer	33131428097	        2		        £12.31
Dust Guard Ring Inner	33131214298	        2			£15.65
Shaft Seal	33107505604	2			                                £18.11
Lock Ring	33131214961	2			                                £1.45
FRONT DIFFERENTIAL
Oil BMW Synthetik OSP	83222365987	        2 Litres	         £59.30
Reinforcement Plate Bolts	31101096987	        6			 £72.19
Reinforcement Plate Nuts	33306760587	        6			 £5.39
				Posted: Fri Nov 13, 2020 9:34 am
				by Smeeagain
				Alan Gunn wrote: Thu Nov 12, 2020 7:39 am
Easy job to do.
Just the correct oil. Immensely helpful. I rather suspect he knew that ........
