central locking issue
rapidspec
Hi guys after some advice if possible, got the X3 e83 2.5i sport, central locking was working fine off the fobb then it stopped and even when i use the key in the door it only locks and unlocks driver door? there is a sound coming from the doors when i press the fobb but no locking? also the door locking button on the dash is not working. any ideas anyone?
- marti
Re: central locking issue
Possibly a low battery in the fob or you could try disconnecting the battery (both pos &neg) for 20 minutes neg off first and on last....it might reset it...
Did you try the spare key always worth a go ?
As above fob battery.
Try a second key if you have one but the battery could well be gone in that one as well.
