4 warning lights at the same time?
Posted: Thu Oct 22, 2020 12:04 pm
by Rocky-S
Had a panic of a phone call yesterday from my wife whilst driving home from work. 4 warning lights came on at the same time?????
Have absolutely no idea where to start,so can anyone please advise? Photo attached below?
Re: 4 warning lights at the same time?
Posted: Fri Oct 23, 2020 7:26 am
by Alan Gunn
Could be a wheel speed sensor ort he reluctor ring but a fault code scan is the best thing to start with.
Posted: Fri Oct 23, 2020 12:42 pm
by rapidspec
Hi same problem with mine, its the abs ring on both my rear driveshafts. rusted up and swelled up, been hitting the abs sensor in the hub. i removed the sensor from the hub and you could see the wear on it, also could see the rusted abs ring through the hole. abs rings £10 a pair but you need to remove the drive shafts p,i,a i have done the near side, old ring just fell off. I dropped the rear of the exhaust and removed the sway bar bolts to allow the driveshaft to be removed
Posted: Sun Mar 07, 2021 8:02 pm
by efcbluepete
I had exactly the same, and it turned out to be the exact same issue as Rapidspec, but with just 1 of the rear wheels.
got the driveshaft off, used an angle grinder to remove the reluctor ring, cleaned up the shaft and fitted one from ebay for just a few quid. Replaced the worn sensor with a genuine BMW version (was warned off replicas by a good friend who has done ABS sensors on a couple of 3 series he's had). Fingers crossed, all is now fine.
Good luck getting it sorted.
Pete
