'Best' tyres (X6)
'Best' tyres (X6)
Post by sapphireblack » Thu Oct 01, 2020 7:56 am
Being a bit of a wheels obsessionist I've just acquired another set of my favourite X6 wheel, type 300 X5/6M.
I don't need to re-boot the car currently but as posted previously, the Continentals fitted last year are wearing quite quickly. Soft and grippy yes, but are destined for a short life. Bridgestones are generally factory fit but they seem hard to me even accepting the runflat status.
As an aside i still have an unused wheel set with Pirelli * winters on them but thoughts have turned again to all weather options, albeit none afaik are runflat. I emailed Vredestein a while ago who confirmed they are happy with their staggered size Quatrac on BMWs fragile transmission. Of course if the tranny had a hissy-fit i doubt they would pick up the bill.
So what to do, fit summer rubber on the new wheel set, Pirelli, Michelin hurt the wallet , Dunlops , Good Year or other? Or be brave and go all season?
PhilT
Re: 'Best' tyres (X6)
Post by PhilT » Thu Oct 01, 2020 2:14 pm
I’ve been running Vredestein Ultrac Vorti’s on my X6 for the last 5 years with no problems at all.
Just about ready for a new set and will stick with them if possible, unless they’ve been superseded by the Quatrac, in which case I’ll give them a try.
Post by X5Sport » Thu Oct 01, 2020 6:18 pm
That’s incredibly useful given I need a set. If they’re prepared to put their stamp of approval then brilliant. :D
Just can’t get them in the 19” rear size 285/45/R19 (so far at least). Fronts 255/50/R19 are fine but not the rears it seems :(
Post by Leslie » Thu Oct 01, 2020 8:15 pm
I'm interested in those tyre pressures 2.8 bar front and 3 bar rear , a lot more than quoted for runflats ! :D
Post by sapphireblack » Fri Oct 02, 2020 6:34 am
X5Sport wrote: Thu Oct 01, 2020 6:18 pm That’s incredibly useful given I need a set. If they’re prepared to put their stamp of approval then brilliant. :D
I think you have to go square, 255 50 19 all round 255 is minimum on a 10" rim but within approved boundaries. That or upsize to 265 widths all round, perfect for 10" rims and maximum on 9".
If BMW dont have a solution to withdrawn tyre sizes they leave it to you, so you have to get creative.
Post by sapphireblack » Fri Oct 02, 2020 6:45 am
Leslie wrote: Thu Oct 01, 2020 8:15 pm I'm interested in those tyre pressures 2.8 bar front and 3 bar rear , a lot more than quoted for runflats ! :D
If i had posted page two it would be useful :roll:
rockwell
Post by rockwell » Fri Oct 02, 2020 11:06 am
I obtained the exact same disclaimer from Vredestein when I enquired about fitting All Season Quatrac Pro 235/55/17 all round on my elderly e83 X3 3.0d manual.
I also received a veiled non committal nod of approval from a BMW main dealer. So far the Quatrac Pro's are a huge improvement on the Pirelli Scorpion STR (M & S)
Post by sapphireblack » Sat Oct 03, 2020 12:20 pm
Are yours a square set? I dont think there's generally an issue with four identical tyres of any type.
Post by X5Sport » Sat Oct 03, 2020 1:15 pm
Currently I can get Pirelli Scorpion winter tyres (I’ve used them since 2011 in RFT with ‘*’ for the front and non ‘*’ for the rear. I’ll check again with BMW to see if I can get any kind of more positive steer that a “well........technically........they should all be ‘*’ marked”. Given it’s the same brand, same tyre type and correct size just not the homologated version on one axle there shouldn’t be an issue. IMHO of course.
rockwell
Post by rockwell » Sat Oct 03, 2020 2:16 pm
sapphireblack wrote: Sat Oct 03, 2020 12:20 pm Are yours a square set? I dont think there's generally an issue with four identical tyres of any type.
Yes, 235/55/17 all round so less of a problem I believe.
X5Sport - you are quite correct to be cautious, and as you said, I doubt the tyre manufacturer would back up their disclaimer financially.
