Door glass Question
Gatecrasha
Door glass Question
Post by Gatecrasha » Thu Aug 13, 2020 1:27 am
Removed dark black tint from rear doors yesterday as I wanted them in clear glass to match front doors
Shocked to find I have 1 black factory tinted door glass
Are there any specific markings on the glass to identify it as being a clear window?
As so many are film tinted I'd like to make sure I get the right one
TIA ;)
Professional Falconer
Re: Door glass Question
Post by X5Sport » Thu Aug 13, 2020 6:54 am
First of all :hi:
Odd one that. Usually all of the glass from the B-pillar back will have been factory tinted (so called sun protection glass) if that option was chosen - and it often was. All OEM glass is/was from Semperit at new, and has a BMW rounded etched on it. There might be a part number on the glass. Front glass was not dark tinted by default, or as a factory option.
One place to look is RealOEM on line. It’s a copy of the current BMW parts database. Use the last 7 characters of your VIN in the ‘serial number’ box and it will pull up the right model/year/market. That will give you the right part numbers to search for a new one. They’re normally 7 or 11 digits, and in this case 11.
I’ve pulled up the page for my old E53. First two of item 03 are the clear class factory fit below:
https://www.realoem.com/bmw/enUS/showpa ... Id=51_3894
As for changing it, another useful resource is newtis.info. It’s a copy of the dealer’s tech/service manual on line.
Gatecrasha
Post by Gatecrasha » Thu Aug 13, 2020 8:40 am
Some useful stuff for me to look into there thankyou ;)
I should also add I think I've sussed why it has the 1 dark glass as my x5 is a bit different in other ways ;)
1 door & interior trims are grey
Yet seating is black
2 steering wheel is pre facelift
I'm suspecting my car was stolen at some point
(Entrry via rear door glass)
Seating and steering wheel probably having been robbed
Post by X5Sport » Thu Aug 13, 2020 12:43 pm
Or someone wanted to fit a new interior but didn’t find all of it on line so you have a mix-up. Some preferred the look of the earlier wheel. I would have thought an insurer would have refitted it correctly - unless it was 3rd party only at the time. Still, there’s nowt as strange as folk..... :?
If you run the VIN through one of the on line BMW VIN decoders it will tell you what the ‘as built’ options were.
Gatecrasha
Post by Gatecrasha » Fri Aug 14, 2020 5:03 pm
Update ;)
Door glass windows have a code on the glass itself to make identification easier so you can avoid buying the incorrect tints.
Eg my clear glass windows show code
43R-004530
While the dark tint window shows
43R-004553
