LED Angel Eyes Flickering ??
- ianmaney
Guys, fitted new LED angel eye bulbs a short while back, when i start the car now they flicker for a few seconds, any ideas why ?????
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
Current Bikes:
GSX-R1000k6 (His)
- Sanj
Re: LED Angel Eyes Flickering ??
It's normal - they are low voltage and can be seen being tested by the car. Nothing to worry about.
- ianmaney
Cheers Sanj, i may go ahead and fit the LED driving lights now then too then !!
Current Cars:
Current Bikes:
GSX-R1000k6 (His)
Current Bikes:
GSX-R1000k6 (His)
- jeegnesh
Yeap happens on mine. We did have an old thread on this in the old world and it was common regardless of which bulbs your bought.
Nice little disco.
Nice little disco.
- Turks
- Contact:
It is only for a few seconds if you have your lights turned off or it is in the day time. If your lights are switched on or you have auto lights you won't get the low voltage test so there is no flicker.
Turks.
Turks.
Present:
Past:
Past:
- jeegnesh
Sure it happens for auto. Mine is always set to auto
- ITBarbie
Mines set to auto and the do it on mine as well
2004 Sapphire Black 3.0d SE
MODS
MODS
- jeegnesh
Pretty sure it happens always because the flickers are when the check tests are sent out
Garry247
Hi guys. I have a 2002 x5d sport just bought says I have xenon. Don't know much about these cars. I do however love it. The lights look like two normal inners and 2 round clear magnified marbles on the outer with a glass ring around them. Are these the xenons. Can I swap out for angel eyes?
Thanks.
Thanks.
- Chompers
Hi Garry (Not Gray
), can you manually adjust the high of your headlights using the wheel on the headlight control panel? If you can they are STD lights if you can't they are Xenon as these self adjust. HTH
EDIT: Note to self, have first cup of coffee in the morning before first post
Current
Previous
Previous
- Turks
- Contact:
[quote=""jeegnesh""]Sure it happens for auto. Mine is always set to auto[/quote]
[quote=""ITBarbie""]Mines set to auto and the do it on mine as well[/quote]
Mine is always set to Auto too...
I don't think I made myself very clear. If your LED's are illuminated, i.e switched on (auto if it is dark), then you shouldn't get this flicker. The only time you will get this is if the LED's are off (auto if light) and it performs the test on startup.
I have only ever noticed the flicker once. This was a reflection on the parked car in front of me in the daylight. Same in my E39, only did it in the daytime for a couple of seconds and then I never noticed it again?
Do you experience different from what I have said?
Turks.
Turks.
Present:
Past:
Past:
- ianmaney
I've also fitted HID's to the car and mine too are always set on auto, however, when its dark, i turn the key and everything burst into life, but when the car is starting up, the headlights go out a wont come back on when the car is running but the angel eyes do, then i have to turn all lights off, set it to 'normal' on, then switch quickly back to auto, pain in the preverbial tbh, they were bought me as a present, could it just be that they're not BMW specific and i need to change them ???
Current Cars:
Current Bikes:
GSX-R1000k6 (His)
Current Bikes:
GSX-R1000k6 (His)
