X53 Level sensor under voltage
Swirly
Post by Swirly » Fri May 15, 2020 4:04 pm
Hi peeps, 2005 E53, I've had it to my mates garage, the supensension inactive warning is on the dash, he has had a play with the sensors, plugged it in and he has said one sensor is under voltage 2.5v, it will reset then take it for a test ride the suspension inactive comes back on, what are your thoughts, wiring problem? Suspension module? Is there a link to a wiring diagram for this year, I'm going to have a look it monday :D
Re: X53 Level sensor under voltage
Post by X5Sport » Fri May 15, 2020 4:20 pm
Wiring diagrams can be found at newtis.info.
The website carries a copy of the same Technical Instructions used at a Dealership. Worth a look. :)
Swirly
Post by Swirly » Fri May 15, 2020 6:15 pm
Thanks :D
