	bmw x5 e53 driver wiper doesnt clean 15cm of window
				kamrulh
hi guys,
im having problem with the driver side wiper, ive changed them so its not individual wiper problem but on the driver side the wiper doesn't clean 15cm of it for some reason
just a circle of water that cant be wiped for some reason, any idea why ?
check with few garages they said they don't no, originally someone said change the wiper which I did but still same problem.
Re: bmw x5 e53 driver wiper doesnt clean 15cm of window
Could be the wiper arm itself.  It might have been slightly bent or twisted and isn’t applying either enough down pressure or keeping the blade at the proper angle on the glass.
				kamrulh
see that's the thing, that's what I thought at first I bought a whole new wiper arm along with new bosch wiper and still that little bit doesn't wipe, in all honesty if it wasn't in the centre of the drivers view I wouldn't have bothered but with storm Dennis I think I need to get it looked into before storm Edward comes in season lol
						- sleepyfolk
Where did you buy your wiper arm and wiper  from? That might be the problem.
I bought new arms from BMW which hold the blades down ok, it’s just the noise I can’t bear from the Bosch blades, gotta try some different ones for my own sanity
				kamrulh
bought the arm from bmw and the wiper from online both spanking new so couldn't even blame the merchant - if I push down on the wiper part where it doesn't
clean that space then the wiper actually does clean it but theres no way to keep the wiper in that same position
- sleepyfolk
You’ve definitely got the right ones for drivers and passenger side as well have you, cos they are  different? Just wondered if it wasn’t the right length that might be something to do with it
The rear wiper on mine does that. It's one from an E70 and in one direction it leaves a big part of the window in the centre where it does not wipe but on the return direction its clears the whole window. Strange. I've tried three different wipers and arms and they are all the same.
				kamrulh
I was curious at the beginning to see if they were same size or not so before I bought anything I knew which ones were short and long, but its the second one on nowsleepyfolk wrote: Thu Feb 20, 2020 1:50 am You’ve definitely got the right ones for drivers and passenger side as well have you, cos they are different? Just wondered if it wasn’t the right length that might be something to do with it
so not sure why it does clean that part of the window
				weirdfish
Not sure if it will help with your problem but I've just changed all three blades on my X5 and had the problem on the rear and the drivers side.
The rear was a simple case of wd40 on the arm pivot point and spring, must have been a little bit tight.
The drivers side blade was being held of the centre section of the screen by the plastic u shaped clip that's attached to the arm, removed this and works a treat.
