timing chain tensioner
- Loperamide
Can anyone tell me the best brand to buy for the timing chain tensioner on the M62TU ?
Most seem to be Febi Bilstein, are these any good?
This is for a 2003 4.4i
- henrym3
Re: timing chain tensioner
I fitted Febi Bilstein to my lads 4.4 some years ago and mine 7k ago so I’m a fan.
- Loperamide
can u link me to where you bought yours, and some installation instructions please?henrym3 wrote: Thu Jan 30, 2020 7:02 pm I fitted Febi Bilstein to my lads 4.4 some years ago and mine 7k ago so I’m a fan.
- henrym3
191743577225 Ebay item No
https://www.newtis.info/tisv2/a/en/e53- ... ft/AqgCmMj
- Loperamide
on RealOEM the part number is different? 11317531813henrym3 wrote: Thu Jan 30, 2020 10:31 pm 191743577225 Ebay item No
https://www.realoem.com/bmw/enUS/showpa ... Id=11_2264
and what about the washer?
Are there any special instructions for the X5 on gaining access to the bolt? How awkward is it?
- henrym3
372858625461
You can go for this same piece from febi which lists the bmw p/n. Both are the same I checked at the time. As for the washer mine came with a washer but if not then you’ll have to go to dealer. I change mine every 30k initially because those in the know recommended it but now having done it there is a noticeable difference in length after 30k. If that keeps better tension on the chain and makes the guides last longer then in my book it’s worth the money.
- Loperamide
Are there any special instructions on gaining access to the bolt? How awkward is it on the X5?henrym3 wrote: Fri Jan 31, 2020 12:51 pm 372858625461
- lezmtaylor
Not that difficult, you may need to remove the air cleaner for more access,
One tip : do NOT play with the new tensioner, ie:, undo it to measure against the old tensioner, I did and found it was impossible to lock new tensioner in the closed position and had to fit unlocked, took ages .
Lez
Lez
- Loperamide
So how will it open by itself? Is it not dangerous to install it closed without any tension on the guide?lezmtaylor wrote: Sat Feb 01, 2020 9:37 am Not that difficult, you may need to remove the air cleaner for more access,
Lez
Every single youtube video out there installs the tensioner in the open position.
- lezmtaylor
Cannot remember how I did it , but I do remember that it was impossible to get it to lock back up to fit it. and refitting against the open spring was hell of a job, perhaps so one on here who has done the job can explain,
Lez
Lez
- sleepyfolk
Bought mine from Cotswold bmw with the forum discount - price was similar to elsewhere to be honest but it was a couple of years ago.
When you’ve managed to squeeze your hand in and change it - it’s awkward as opposed to difficult or requiring any skill! As Lez says don’t open it beforehand or it will be bloody difficult, the oil pressure will open it when you start the engine.
Unfortunately there will be an almighty clatter and you’ll think you’ve totalled your engine for about 1.5 seconds but that’s normal, or you can pay someone to do it and you just won’t hear it!
- Loperamide
That clatter for 1.5 seconds could cause the plastic guides to break off with the chain slapping around, if they are already very brittle with age.sleepyfolk wrote: Sun Feb 02, 2020 11:54 pm Bought mine from Cotswold bmw with the forum discount - price was similar to elsewhere to be honest but it was a couple of years ago.
Unfortunately there will be an almighty clatter and you’ll think you’ve totalled your engine for about 1.5 seconds but that’s normal, or you can pay someone to do it and you just won’t hear it!![]()
- sleepyfolk
If you find a way round it post it up, I couldn’t find one
- henrym3
I took the tough route, it is doable, just needs a lot of pushing in while trying to turn.
- Loperamide
Too late. It arrived in the open position today!lezmtaylor wrote: Sat Feb 01, 2020 9:37 am Not that difficult, you may need to remove the air cleaner for more access,
Lez
