Business Radio & CD Not Working - Try This
Posted: Fri Dec 27, 2019 5:00 pm
Eh up all
Well took the X5 out the other day to put some fuel in the tank, decided to put the radio on, something I do not do often as like to listen to the car - see if I can hear anything going wrong
Anyway no radio at all ?
Got home and checked again, nothing when pressing the button, but I could get time, distance et .
So read the forum and tried a few options on a possible fix, easiest first:-
Checked in boot fuses 73 and 75 ( think that’s what they were but it’s listed anyway) took out even though they were ok and put back in, still no radio.
Went into glovebox and did same with fuse 7, that was still ok, put back in and still no radio.
Then removed the battery for a couple of minutes, negative lead only, and reconnected- still no radio
Finally took the radio out and disconnected, and the actual CD as I understand this is the main unit that controls the radio. On removing the CD unit block connector and also the 10amp fuse ( which was ok so just reseated it) then reconnecting after a few minutes the CD unit powered up.
I reconnected the radio unit below and switched the ignition on -success :
No idea why this worked - it’s electronic so is therefore beyond all reasoning!
Anyway thought I would post in case this “fix” worked for anyone else.
HNY folks -
Cheers all
HNY folks -
Cheers all
