X5 e53 diesel crank but no start
Fireblade901
Hi just brought an x5 diesel 2002 with 80,000 miles problem I’ve got is it cranks over really well but won’t start?changed inline pump under car and fuel filter.like to know what’s the next thing I should try?sensors leak off test (can this be done without running car) cheers for any help Craig
Re: X5 e53 diesel crank but no start
Have you had the codes read, it could be several things, if it's the high pressure fuel pump it would have flagged a low rail pressure fault code, etc, or camshaft sensor will throw a code etc
Randomly changing parts will be a costly guessing game.
- marti
As above , get the codes read.....unless you have deep pockets!
Fireblade901
When aa bloke came out the codes it come up with was pressure too low status :09F6_10 hope you can help?
- marti
You will get the low pressure code if the battery is low.
Was it running okay prior then when you tried to start it...nothing?...if so it maybe an injector gone down....get yourself a can of easi-start blast loads in the in the airbox...if possible get someone to crank it over as you spray it in.....if she fires up and keeps going its probably injector 5 at a guess....
Injector 3 and 5 had gone in mine but my starting problem was only when it was hot.
It would start again if left for 10/15 minutes.
Code on mine was for low fuel pressure on start or startup.
OnlineLeslie
You may have replaced the fuel pump but does it actually run now ie old one blew the fuse when it went faulty ? If you listen close to it you should be able to hear it for a few secs when ignition turned on ?
I'm guessing this car was very cheap as if it was a non runner Id be running the other way usually !!!!!!!!
Fireblade901
Only reason I’m thinking it’s fuel related is because when I prime system I’m getting bubbles in fuel line from filter to high pressure pump so it’s not pressurised the diesel system looking for cheapest option only paid £400 with just under 80000 miles wouldn’t think injectors would go that early?maybe I could be wrong cheers for all your reply’s
- marti
Try the easi-start , if it doesnt fire up on that then its not an injector.Fireblade901 wrote: Mon Dec 16, 2019 1:27 pm Only reason I’m thinking it’s fuel related is because when I prime system I’m getting bubbles in fuel line from filter to high pressure pump so it’s not pressurised the diesel system looking for cheapest option only paid £400 with just under 80000 miles wouldn’t think injectors would go that early?maybe I could be wrong cheers for all your reply’s
Fireblade901
Hi got this sorted was intank pump nice cheap repair thanks for all your help and advice Craig
- marti
Fireblade901 wrote: Tue Jan 07, 2020 9:59 pm Hi got this sorted was intank pump nice cheap repair thanks for all your help and advice Craig
Thats a result, never had one go myself.
OnlineLeslie
Does that pump just move fuel from one side to the other ?, heard of this on 3 series etc where if you have say half a tank of fuel it will run without it as the fuel can get across but on low fuel it needs the pump to get over the hump in the tank, was it low on fuel ?
