Tyre recommendations.
charlie_bendall
Hi I need to change all 4 tyres on my partners x3. I know all about tyre problems etc. I'm just after people's recommendations for which is best in terms or wear, performance etc. Obviously only Bmw approved tyres. Currently it has Pirelli scorpions fitted. Thanks
Osprey2
Re: Tyre recommendations.
I have a F25 X3 (X-drive) and it's fitted with P7 RFT. I wouldn't recommend these are they are dire!! Still around 4mm rear and 5mm front and they are beginning to 'step' and make that wheel bearing type noise already. Same happened with the last set and similar depth. I hope there are some alternatives out there and I'll probably change over to non- RFTs with a kit in the boot
- marti
I always go for Conti's and Verdstein both non runflat, never really had any issues.
rockwell
I have Pirelli Scorpion STR 235/55/R17 all round My first set lasted well, unfortunately not the case with my current set.
I'm thinking of switching to Michelin Cross climate, not sure if they are star marked or not but probably not an issue as all four are the same.
rockwell
I'm receiving conflicting info on tyres for the above, a 2006 x3 with 235/55/R17 front and rear. Is there any reason why I shouldn't use premium all season tyres, even if they are not * marked and recommended by BMW? I'm being cautious as I have recently had the transfer case rebuilt and would prefer not to repeat the experience!rockwell wrote: Mon Dec 30, 2019 12:09 pm I have Pirelli Scorpion STR 235/55/R17 all round My first set lasted well, unfortunately not the case with my current set.
