Intake manifold gaskets replacement bmw vs ebay
cooa99
Post by cooa99 » Wed Dec 04, 2019 12:29 pm
Hi all,
I am going to be replacing my glow plugs so the 12 gaskets on the intake manifold will need replacing.
About £25 on ebay while its £100 from the dealers.
Anyone used the ebay ones and are they of same quality?
Re: Intake manifold gaskets replacement bmw vs ebay
Post by marti » Thu Dec 05, 2019 7:02 am
Ive used them many times and all has been fine, no difference I can see between BMW and eBay, but you need the whole set and not just the 12 port gaskets....
cooa99
Post by cooa99 » Thu Dec 05, 2019 12:51 pm
marti wrote: Thu Dec 05, 2019 7:02 am Ive used them many times and all has been fine, no difference I can see between BMW and eBay, but you need the whole set and not just the 12 port gaskets....
HI marti, I can only see adverts for 12 or 13 gaskets. Any idea or pictures of others than need replacing?
I don't know if I have blanked swirl flaps so wondering if i should do them as well. It is a 2005 facelift version
Post by marti » Fri Dec 06, 2019 7:04 am
This is the set you require: https://www.ebay.co.uk/itm/Intake-Manif ... SwFZZcHiv9
As for swirl flaps I dont think you have them, however you can always buy this set in case, which is what I did: https://www.ebay.co.uk/itm/REPAIR-KIT-S ... SwlNtdQU2f
When removing the manifold put plenty of sheets around the engine bay to stop you losing various nuts etc...or youll be dropping the undersheild to find various dropped bits...
cooa99
Post by cooa99 » Fri Dec 06, 2019 3:02 pm
Thanks very much
