Im new here, got my 2012 20d Msport back in May, after changing from our 2010 X5 40D.
Its running 19"'s and the last couple of months have eaten the inside tread, I know its an issue. With the X5 I used some advice online to reduce the toe in to almost zero using an independant with a Hunter machine, that seemed to do the trick.
Has anyone done the same with the F25 or have a copy of the alignment specs? I know the factory settings are notoriously wide in their scope on the X5
