Hi All,
I have F25 X3 2014, recently it has developed a problem with Tailgate, so I am looking for guidance or a solution.
The tailgate has powered button to close it down, as you all know. Last night I pushed it to shut it down, after doing groceries, and while the gate was being closed down, my younger Son pushed the button again and the operation was intercepted, so I had to reopen the it and closed it.
Next day I tried to open the tailgate it didn’t; I tried too many time through key button, internal button and the back latch but couldn’t open it
When I push the button to open it, I can hear the noise of servo motor but the door does not get released from the locking mechanism.
Is it a mechanical failure? If yes is there any way to open the tailgate manually?
Or is it an electronic control failure, which needs resetting the error or replacing any instrument / sensor?
Regards
Tailgate Stuck/ Does not open
- marti
Re: Tailgate Stuck/ Does not open
Does it not have a key lock?
Wellatori
Not for the tailgate
- marti
Can you get to the battery by dropping the seats....try the magic reset...disconnect it for 20 minutes minimum...
Wellatori
I don't know how to do that, is it under the driving seat?
OnlineAlan Gunn
No it's under the boot floor right at the back of the car.Wellatori wrote: Fri Sep 27, 2019 9:18 am I don't know how to do that, is it under the driving seat?
Google will show you how.
- StuBeeDoo
Just checked in my owner's manual. It says..............
In the case of electrical defect, operate the unlocked tailgate manually, proceeding slowly and avoiding sudden movements.
and concludes.....
Contact a Service Centre
HTH
