Stupid question time?
Post by sapphireblack » Tue Sep 10, 2019 7:07 am
I want to change the cars steering wheel which obviously means a battery disconnect.
Now I've done this several times in the past on other vehicles by pulling the negative terminal on the battery. As an E71 battery is a bit of hassle to access, will the under-bonnet terminal afford me the same safeguard of full power disconnect? I can't imagine it doesn't but I'm checking to be sure.
Laugh now if appropriate and desired :oops: :wink:
Re: Stupid question time?
Post by Alan Gunn » Tue Sep 10, 2019 8:17 am
I don't think it will disconnect everything.
Could be wrong but there are a few wires attached to the battery + connection block i think.
Somebody correct me :?
Post by StuBeeDoo » Tue Sep 10, 2019 11:00 am
+1 on "don't think it will disconnect everything". It might be a faff-on, but disconnecting the battery -ve terminal is the only way to be certain.
Post by sapphireblack » Tue Sep 10, 2019 1:19 pm
I thought as much. Oh well more effort required :x
Post by marti » Tue Sep 10, 2019 3:39 pm
Disconnect it in the boot.....
Post by Leslie » Tue Sep 10, 2019 4:56 pm
Never take a chance with an airbag near you face !
