rear wiper sluggish
Smeeagain
rear wiper sluggish
Post by Smeeagain » Mon Aug 12, 2019 9:36 am
Has anyone had this issue - my rear wiper motor appears to be sluggish - really slow across the rear screen often stopping at the halfway mark. I took the wiper arm off and cleared out all the crap etc and cleaned the glass with polish (to reduce surface tension). It helped a bit but it is not great.
Anyone had this problem - I assume the wiper motor is on the way out but anted to check and see if it was something simple before doing that?
Smee
Re: rear wiper sluggish
Post by marti » Mon Aug 12, 2019 4:27 pm
As youve said motor on its way out.
weirdfish
Post by weirdfish » Mon Aug 12, 2019 6:38 pm
Motors either work or don't, I would think it's something like a partially seized drive shaft from the motor to the actual wiper arm itself.
Strip down as much as you can and give it a good clean, lubricate and re-assemble.
Might be just as bad, but at least it's cost you jack shit to try.
Post by Themoog2 » Thu Aug 15, 2019 5:50 am
Nah. Same happened to mine a few years ago. I did all the cleaning etc to no avail so in the end I just swapped the motor.
