Front brake pads
ssrfr03
Front brake pads
Post by ssrfr03 » Sun Aug 11, 2019 7:38 pm
Anyone know how many miles I have left as the brake wire warning has just popped up ie about 1000 miles or 2000 if I am lucky ??
Re: Front brake pads
Post by StuBeeDoo » Sun Aug 11, 2019 8:00 pm
How long is a piece of string??
IMHO, if the light is on it's not a question of how long - it's time to get them changed. ..........Especially as the warning only relates to one pad per axle. Pads rarely wear totally evenly - you could already have one or more pads even more worn than the one with the sensor on.
Post by X5Sport » Sun Aug 11, 2019 8:18 pm
As said above, if the light is on then they need doing sooner rather than later, and also as above the wear is uneven with inboard pads wearing faster (based upon all of our single piston caliper equipped BMWs). You might get 1,000 miles, or 50.
It’s a pretty easy change process and only takes about an hour or so including getting the car jacked up and the wheels off/on again. Pads are (last time I bought any) about £50 and the sensor about £10 from Carparts4less (ECP by another name) with one of their frequent mega discounts (or about £100 from BMW as a ‘valueline service kit’).
I use Pagid on all mine.
Post by Leslie » Sun Aug 11, 2019 8:21 pm
Best to look though the wheel and see what "meat" is left on them before it hits the backing pad but as said expect the inner pads you can't see to be much worse.
ssrfr03
Post by ssrfr03 » Sun Aug 11, 2019 9:07 pm
Thanks for the answer light came on this morning when leaving South Shields down to cambridge 227 miles so tomorrow morning early cambridge to Portsmouth 170 miles Caen to house in france 179 miles I hope I make it with out damaged to disks I have spare pads and sensor out there so be changing the them on Tuesday all being well
Post by StuBeeDoo » Tue Aug 13, 2019 8:21 am
ssrfr03 wrote: Sun Aug 11, 2019 9:07 pm changing the them on Tuesday all being well
Let us know what you find. :thumbsup:
Waka
Post by Waka » Tue Aug 13, 2019 1:53 pm
On a sort of related note, my rear pads have said they have about 1200 miles left...and have been saying that for about 6000 miles. :?
