X5 e53 clutch and flywheel parts
Bennsewell86
Post by Bennsewell86 » Fri Jul 19, 2019 9:56 pm
Hi all.
I have a 3.0i manual e53 in need of a flywheel and clutch replacement.
I'm getting mixed answers of whether other BMW parts, such as that of an e46 3.0 would fit.
Could someone please clarify whether the parts from a similar M54 engine would indeed fit, or whether my parts need to be specifically for the e53 3.0i.
Thanks very much.
Benn
Re: X5 e53 clutch and flywheel parts
Post by X5Sport » Sat Jul 20, 2019 8:00 am
According to Realoem the same clutch kit is used on the 5 and 6 series but not the E46. I would assume the gearboxes are the same in those cars so they have a common clutch. If you haven’t come across that site, it is an up to date copy of the BMW parts database.
The flywheel again is 5 series, Mk1 X3 and X5 only.
Use the last 7 of your VIN on Realoem (in serial number) for identifying the parts.p, then go hunting. :)
Bennsewell86
Post by Bennsewell86 » Sat Jul 20, 2019 1:54 pm
Thanks very much.
I went on realoem last night with numberplate and not VIN.
It seemed to think e36, e46, z3 and 5 series flywheels would all fit.
I'll try again with correct VIN.
Thanks for your help again
Post by marti » Sun Jul 21, 2019 4:23 pm
Bennsewell86 wrote: Sat Jul 20, 2019 1:54 pm Thanks very much.
Never heard of the number plate in realoem working.....I'll try it now....Nope! :cry: ..just comes up with:
https://www.realoem.com/bmw/enUS/select?vin=X60BMV
