Hi,
I own a 2005 3.0d Manual and have noticed this morning that where the display says Mileage Trip and Temp it is bright on the Mileage and then dims down considerably so you can barely see the Temp. Do I have a bulb malfunction and if so is it easy to rectify. Look forward to any help.
Jt
	dashboard pixel light issue
Re: dashboard pixel light issue
I can assure you it's not an easy d.i.y. job................  Click here for tried & tested repairer used by others.
On another subject your input might be appreciated on this thread as manual owners are thin on the ground.
				ayat
luckily when i bought my x it had a pixel fault but car came with a warranty, the diy jobs dont always rectify the problem and isnt easy, my dash assemble was replaced with the warrant at a cost of nearly £800.
