BMW E53 X5 new discs front and rear
sid10
Bought these for the E53 front and rear discs from a main dealer will post oem part numbers later £200 for all 4 .
- shy7g
Re: BMW E53 X5 new discs front and rear
Hi are the disc still available?sid10 wrote: Mon Jul 01, 2019 2:50 pm Bought these for the E53 front and rear discs from a main dealer will post oem part numbers later £200 for all 4 .
Will the disc's fiit all variants of the E53 range, as I have the 4.6iS model?
Rich
If the fronts are 332mmx30mm then no, you need 356x36 (used on the 4.6/4.8 V8s). 4.4 and 3.0 models use smaller front discs.
Your rears are 324x20mm (common to all V8 versions). 3.0d uses 324x12mm
