Hi all where can I find the aux connection to fit reverse cam or ps3 are they behind monitor or in the boot
Thanks wilko
	Sat nav aux
- Sanj
Re: Sat nav aux
Yeap - use that diagram you posted with this link:
viewtopic.php?f=22&t=86&start=15#p571
Tells you where to make the connections and the relay you'll also need.
The TV Module is in the boot under spare, compressor and black cover around the battery.
