E53 Number plate lens and gasket
Edward R-W
Does anyone know the part numbers of the number plate light lens and rubber gasket, and where to buy them from? All I can seem to find on the net is cheap LED replacement lamps fixed to a lens that look like they could catch fire at any point.
Re: E53 Number plate lens and gasket
Try Realoem for the part number. It’s a copy of the official parts database on line. You need the last 7 of your VIN in the ‘Serial number’ box to oull up your model. Could be in Electrics, Lighting or Vehicle Trim sections.
Never anthropomorphise computers. They hate that.- hennabm
They are still available from BMW.
I bought one last year and a spray tin of colour from BMW as they only come in primer.
I rubbed it down with 1500 and then the colour, followed by the clear lacquer.
Easy to change as a few screws and the electrical connection. That may need some cleaning if water has got into it.
wpoll
Are you referring to the entire handle assembly? The lens itself is BMW #51137062293 but it doesn't have the gasket....hennabm wrote: Mon Jul 08, 2019 10:35 am They are still available from BMW.
- hennabm
Sorry, yes I was referring to the whole handle assembly. It comes with new lenses and gaskets as well.
