				Juddering
				Posted: Sat Jun 08, 2019 6:35 pm
				by mrkiplin1986
				Driving my wifes 2013 x3 in stop start traffic if you accelerate briefly up to say 10mph and let off it feels clunky
  its fine through all gears and its only wen u are going very slowly and let off throttle any ideas anyone? Iv read its normal but surely not
				Re: Juddering
				Posted: Sun Jun 09, 2019 9:02 am
				by StuBeeDoo
				mrkiplin1986 wrote: Sat Jun 08, 2019 6:35 pmIv read its normal but surely not
This isn't much of an answer, but have you tried driving another similar car to see if you can replicate it?  Maybe feign interest in one for sale near you.
				Re: Juddering
				Posted: Sun Jun 09, 2019 5:59 pm
				by mrkiplin1986
				We had a 35d before and it didnt do it iv read all sorts about odd tyres, transfer fluid, gearbox fluid, cant be clutch as its smoothe 99.9% of time
				Re: Juddering
				Posted: Thu Jun 27, 2019 10:26 pm
				by SEANRGEE
				My experience would suggest the gearbox software needs a reset - when was the last time the car did a significant mileage journey?  The transmission fluid could likely do with a change also.
				Re: Juddering
				Posted: Fri Jun 28, 2019 7:06 am
				by mrkiplin1986
				Its weird because its super smooth all the rest of the time, iv read to be weary of changing the transmission fluid? How do i go about resetting the software?
				Re: Juddering
				Posted: Fri Jun 28, 2019 9:05 am
				by Alan Gunn
				mrkiplin1986 wrote: Fri Jun 28, 2019 7:06 am
Nothing wrong with changing the fluid and filter as long as the correct fluid is used.
Also filling to the correct level using the correct procedure.
				Re: Juddering
				Posted: Fri Jun 28, 2019 2:56 pm
				by marti
				Are you sure you havent got a broken front spring or a worn joint....??
				Re: Juddering
				Posted: Fri Jun 28, 2019 4:19 pm
				by mrkiplin1986
				Ill check springs but it makes no noise over bumps or anything so i dont think it will be that
				Re: Juddering
				Posted: Sun Jul 21, 2019 10:41 pm
				by SEANRGEE
				Search BMW transmission reset process.  Very simple, ignition on (do not start engine).  Throttle to the floor for at least 30secs.  Turn off ignition.  Take foot of peddle.
Leave for around 10 mins before driving again.  You should notice the gearbox behaviour changes as it goes back into 'learning' mode for approx next 1000 miles.
It's worth doing periodically or at least once a year.  Not guaranteed to solve your problem of course.
