Juddering
mrkiplin1986
Juddering
Post by mrkiplin1986 » Sat Jun 08, 2019 6:35 pm
Driving my wifes 2013 x3 in stop start traffic if you accelerate briefly up to say 10mph and let off it feels clunky :( its fine through all gears and its only wen u are going very slowly and let off throttle any ideas anyone? Iv read its normal but surely not
Re: Juddering
Post by StuBeeDoo » Sun Jun 09, 2019 9:02 am
mrkiplin1986 wrote: Sat Jun 08, 2019 6:35 pmIv read its normal but surely not
This isn't much of an answer, but have you tried driving another similar car to see if you can replicate it? Maybe feign interest in one for sale near you.
mrkiplin1986
Re: Juddering
Post by mrkiplin1986 » Sun Jun 09, 2019 5:59 pm
We had a 35d before and it didnt do it iv read all sorts about odd tyres, transfer fluid, gearbox fluid, cant be clutch as its smoothe 99.9% of time
SEANRGEE
Re: Juddering
Post by SEANRGEE » Thu Jun 27, 2019 10:26 pm
My experience would suggest the gearbox software needs a reset - when was the last time the car did a significant mileage journey? The transmission fluid could likely do with a change also.
mrkiplin1986
Re: Juddering
Post by mrkiplin1986 » Fri Jun 28, 2019 7:06 am
Its weird because its super smooth all the rest of the time, iv read to be weary of changing the transmission fluid? How do i go about resetting the software?
Re: Juddering
Post by Alan Gunn » Fri Jun 28, 2019 9:05 am
mrkiplin1986 wrote: Fri Jun 28, 2019 7:06 am Its weird because its super smooth all the rest of the time, iv read to be weary of changing the transmission fluid? How do i go about resetting the software?
Nothing wrong with changing the fluid and filter as long as the correct fluid is used.
Also filling to the correct level using the correct procedure.
Re: Juddering
Post by marti » Fri Jun 28, 2019 2:56 pm
Are you sure you havent got a broken front spring or a worn joint....??
mrkiplin1986
Re: Juddering
Post by mrkiplin1986 » Fri Jun 28, 2019 4:19 pm
Ill check springs but it makes no noise over bumps or anything so i dont think it will be that
SEANRGEE
Re: Juddering
Post by SEANRGEE » Sun Jul 21, 2019 10:41 pm
Search BMW transmission reset process. Very simple, ignition on (do not start engine). Throttle to the floor for at least 30secs. Turn off ignition. Take foot of peddle.
Leave for around 10 mins before driving again. You should notice the gearbox behaviour changes as it goes back into 'learning' mode for approx next 1000 miles.
It's worth doing periodically or at least once a year. Not guaranteed to solve your problem of course.
