Alternator whining noise
X5-MK
Post by X5-MK » Sun Apr 10, 2011 7:11 pm
Hi Guys
Ever since I installed Dvd, Parrot Bluetooth and Freeview I'm getting an Alternator whining noise coming out of the front door tweeter speaker.
Any thoughts on how to get rid?
Michael
BMW X5 4.6iS V8 SPORT
Sanj
Re: Alternator whining noise
Post by Sanj » Sun Apr 10, 2011 9:27 pm
Always down to bad earthing. Check where you have earthed to. Scrape the paint away, not just connect to bolt hole. Make the earth as short as poss.
Got anything like ground loop isolators in place (should be last ditched effort though). Before that, make sure all cables that run to audio are 'away' from positive cables, or near battery.
This is a right PITA clueso job but can be eliminated with time and patience... :thumbsdown:
X5-MK
Post by X5-MK » Sun Apr 10, 2011 11:47 pm
Cheers Sanj
So I just check to see if all earth cables from all components are touching to bare metal?
Michael
Post by X5Sport » Mon Apr 11, 2011 4:40 am
Yes. Any 'contaminant' will raise the resistance of the connection which could lead to something earthing via a different (and longer) path and that can lead to the issue. As Sanj suggests, all cobtacts should be clean and 'metal to metal'. In some areas of the vehicle BMW provide multiple earth connector plates with fingers onto which the earths go.
