Brake warning light
Lincspoacher
Brake warning light
Post by Lincspoacher » Tue May 21, 2019 8:44 am
Got a message to change brake pads, changed the front and the message went away but im left with a red warning light above the handbrake light,
Re: Brake warning light
Post by Alan Gunn » Tue May 21, 2019 10:44 am
Did you fit a new wear sensor.
Lincspoacher
Post by Lincspoacher » Tue May 21, 2019 12:46 pm
What a wear senser?
Post by Alan Gunn » Tue May 21, 2019 5:22 pm
Front near side and rear off side have a sensor on them that clips on one pad.
Lincspoacher
Post by Lincspoacher » Tue May 21, 2019 5:23 pm
Thanks theres a rubber socket clipped to the caliper but nothing plugged in
Post by X5Sport » Tue May 21, 2019 5:53 pm
There should be a cable that clips into the back of one pad (into a recess) and that plugs into that socket. It’s only on one pad on one side.
Once ‘tripped’ it needs a new sensor - about £12 from memory - plugged in to make the warning light go away. I’m puzzled as to how the warning came on if there was no sensor to indicate worn pads unless someone frigged it and that has now fallen out.
Lincspoacher
Post by Lincspoacher » Tue May 21, 2019 5:56 pm
So am i but thanks
Lincspoacher
Post by Lincspoacher » Thu Jun 13, 2019 9:19 am
Many thanks for the advice, replaced everything and lights still on, did about 30 miles and they've gone out so now seems fine
