				Auto mirrors
				Posted: Sun Apr 10, 2011 12:33 pm
				by wilkoturbo
				Hi all my auto mirror fold in then back out again I've found the the how to and done what it says but still no joy any help please thanks again
				Re: Auto mirrors
				Posted: Sun Apr 10, 2011 1:33 pm
				by Sanj
				This is the link you must have looked at:
viewtopic.php?f=22&t=88&start=15#p578
What did you do? Check the micro-switch?
				Auto mirrors
				Posted: Sun Apr 10, 2011 1:50 pm
				by wilkoturbo
				Yeah and the switch seems to be clicking ??
				Re: Auto mirrors
				Posted: Sun Apr 10, 2011 2:14 pm
				by Sanj
				You've had both covers off and checked both mirrors?
				Auto mirrors
				Posted: Sun Apr 10, 2011 2:18 pm
				by wilkoturbo
				Yep both swtches work or is there a way to check em thanks a million
				Re: Auto mirrors
				Posted: Sun Apr 10, 2011 2:32 pm
				by Sanj
				[quote=""wilkoturbo""]is there a way to check em[/quote]
You have to get the covers off the switches. As per link, they may look like they are switching but they could be loose in the casing. You need to get them out and check they're seated on their pivot points correctly.
Lovely day for it!
				Auto mirrors
				Posted: Sun Apr 10, 2011 3:34 pm
				by wilkoturbo
				O yes I've been sat in the car all day posting to u lol what should happen when the switches are pressed ??
				Re: Auto mirrors
				Posted: Sun Apr 10, 2011 8:19 pm
				by Sanj
				My explanation a while back was long winded and with all due respect, prefer not to repaeat it...
BUT the short version, 2 actuator switches, one lever arm, move to one position, one actuator switch gets pressed, car knows where mirrors are, press window switch, mirrors move to press actuator number 2, via lever arm and car now knows where the mirrors have opened to (new position). ANY interuption in this process and you get the flappy mirrors. If the arm is not pivoted properly, you have no push of that 2nd actuator and no correct message sent... even if you think you hear it, get in there and check it. It may sound like it is pressing but may not be striking the button...
				Auto mirrors
				Posted: Mon Apr 11, 2011 8:39 am
				by wilkoturbo
				Many thanks for all your help hope to meet some of ya at the meets !!
				Re: Auto mirrors
				Posted: Mon Apr 11, 2011 3:53 pm
				by Sanj
				Just to add, I gave some duff info there. It is one switch that gets pressed, not two.
The lever arm gets pressed when the mirror moves, inside are two raised points, that push on the lever arm and then the switch. These are placed where the mirror would fully open and fully close. If the lever arm doesn't sit properly, it doesn't make that contact with switch, then you get the mirrors fold in/out.
Sorry about the duff info.
				Auto mirrors
				Posted: Mon Apr 11, 2011 6:58 pm
				by wilkoturbo
				Many thanks will check this weekend my micro switch is pressed when they are open the off then on again when in the closed position is this right ??
				Re: Auto mirrors
				Posted: Mon Apr 11, 2011 7:53 pm
				by Sanj
				Yeah but you won't be able to tell, the whole lot needs to be encased to be in the correct position.
Open it, see if the lever arm is dislodged - if so, there's your problem.
