Various electronic problems
Posted: Tue Apr 09, 2019 6:50 am
by Chuck Chaffey
Hi Guy's,
Hoping to find some answers for the following problems:
1. Reverse camera not working but in it's place the navigation map comes up , the PDC is functioning.
2. Bluetooth does not seem to be working (My phone doesn't detect anything)
3. Voice control doesn't hear me, but I can hear the beep and it tell me it doesn't understand me.
4. The auxiliary port (3.5mm jack) in the armrest doesn't seem to work although its available in the entertainment hub.
I have replaced the media module in the trunk as it showed water damage, but that didn't seem to change anything.
Could it be another module that controls all or some of these features.
The radio and CD work as does Nav,
Thanks in advance
Chuck
Re: Various electronic problems
Posted: Tue Apr 09, 2019 9:01 am
by Alan Gunn
I would start with a fault code scan as guessing can cost a lot.
Posted: Tue Apr 09, 2019 11:36 am
by XP3NNY
Also if you had a water damage to the control unit it could corroded wires so they might need replacing too, but as Alan said, the best start is quick fault scan
Posted: Tue Apr 09, 2019 12:36 pm
by Chuck Chaffey
Thanks for the quick replies guys, another thing I found today after studying the MOST system was that there is no red glow on the MOST connector which, from what I can see may be the amplifier at fault, but will do a scan and see what that comes up with.
Regards
Chuck
Posted: Tue Apr 09, 2019 6:36 pm
by marti
You will need a scan via a BMW specific diagnostics and not a generic scanner.
Posted: Thu Apr 11, 2019 12:32 pm
by Chuck Chaffey
Hi all,
I ran a Scan with Carly and this what it came up with:
Instrument cluster / Kombiinstrument
Fault Code: 00A554
Fault Explanation: :ALIVE error Phone / live phone
Car Communication Computer CCC
Fault Code: 00E18F
Fault Explanation: :Central Registry does not match the target
configuration (Error Registry New).
Fault Code: 00E18D
Fault Explanation: :Awakening device has three times
unsuccessfully, the network tries to awaken (Error WakeUp Failed) /
Awakening device has unsuccessfully tried to wake the network times.
3 (Error WakeUp Failed).
Junction Box Passenger / Beifahrer
Fault Code: 00A737
Fault Explanation: :K-CAN MESSAGE (ID2BF, VALVE): FAILURE BY
TIMEOUT
I don't know about you guys but, I'm a little puzzled to say the least.
If someone understands any of these faults, please share.
Cheers Chuck
