auto headlight switch - seems to have a mind of its own!
- Alchemist
Hi all,
Bit embarrassed to be posting this but can someone tell me how the auto-headlight switch works? I generally leave it in the 'auto' setting (turned to the left with the green light on). Unlike my 3 series, I can see the switch is motorised but it seems I'm getting in the car in broad daylight and it's turned itself to the dipped beam setting with headlights on before I even start the engine!
Can someone explain how it (is supposed to) works?
Andrew
Andrew
- marti
Re: auto headlight switch - seems to have a mind of its own!
Mine kept doing that....but only when the wife used it!...as when she got in the car she was knocking the switch with her leg/knee without knowing it....maybe thats whats happening??
- Alchemist
Ha! no - i did think that, but have checked and we're not touching it...
EdwardGam
- Contact:
auto headlight switch seems to have a mind of its own
a tune can not and does not change on its own.. the only way a tune can change, is if you change it...
What makes you think that the light switch is motorised? Just curious because I’ve not seen that on any BMW that I have had or currently own. Seems an odd thing to motorise, but then again it is a BMW after all, and they do like ‘driver aids’. The one in my X6 (so should be the same as the E70 is purely manual.
Nictrix
I posted something similar a while ago. I thought I was going mad but I did catch myself nudging the switch with my knee and turning the lights on.
Schoolboy error on my part that may be relevant?
In the menu i had selected DRLs on without realising that negates the auto on/off function. Check what settings are ticked in the menu choices. If DRLs are selected they illuminate immediately.
mr angry
Thats odd, as I have DRLs on and the auto lights function works too
- marti
Same heremr angry wrote: Mon Mar 25, 2019 5:03 pm Thats odd, as I have DRLs on and the auto lights function works too
Mine too.
Well i need to have another look and knob twiddle it seems
Glen
It will be your knee same was happening to me I thought the bloody thing was haunted
