Windscreen washer jets. WITH PICTURE
coolhandluke11
Post by coolhandluke11 » Fri Mar 15, 2019 6:05 am
New to me x5 LCI, blocked washer jets,
I noticed water firing out the side of the bonnet..
On inspection, it's like on the last nozzle (passenger side), there's a male hose connector on the right side of the nozzle as you look at it with the bonnet up, where I'd expect an elbow. The barbed end of the connector looked cleaner than the other elements so looks like there was a pipe or end cap there that's been blown off.?
Can anyone please tell me if it should be a hose connected to this or a cap. If it's a hose, there does it go?
Thanks.
Last edited by coolhandluke11 on Sat Mar 16, 2019 5:34 pm, edited 1 time in total.
Re: Windscreen washer jets. WITH PICTURE
Post by X5Sport » Fri Mar 15, 2019 6:29 pm
No piccie. Says ‘image’ in a small box.
gmc15
Post by gmc15 » Fri Mar 15, 2019 7:50 pm
X5Sport wrote: Fri Mar 15, 2019 6:29 pm No piccie. Says ‘image’ in a small box.
I can see the picture, not sure why you can't :(
I don't think anything is supposed to be attached to the open nozzel shown, I think it is blanked off inside the jet unit. When you use the washers does anything come out of the open end?
Post by marti » Fri Mar 15, 2019 11:15 pm
Cant see pic.....just got what looks like a no entry sign in the middle of the page :?
gmc15
Post by gmc15 » Sat Mar 16, 2019 8:07 am
I can't see the picture now :?
coolhandluke11
Post by coolhandluke11 » Sat Mar 16, 2019 5:17 pm
Sorted, I bought some 4mm id hose from Halfords for £3 (theres 2.9m left!), tied a knot in it and pushed that on. Guess it was blanked off but its shot off.
For info, water just shot out the end of the hose fitting prior to adding the knotted tube.
