	warning triangle
				Colin
warning triangle
Got the yellow triangle with the 4x4 on the dash    steering angle sensor ?  oh have done steering lock 2 lock but no change
						- marti
Re: warning triangle
Could be a number of things, are there any other lights on or does the radio light go off?, diagnostics would be a good start.
Could be:
ABS sensor.
Transfer gear.
Low battery voltage.
Alternator.
						Could be:
ABS sensor.
Transfer gear.
Alternator.
				Colin
Thanks Marti    no other lights on    alternator rewound 2 month ago   batt two year old ,  will try diagnostics
						- briankerrys47
Happend to me tonight  generaly low battery,had not used car for 3 days did  13 mile run with 3 starts  car left for 3 hours then had to jump start triangle disappeared after  800mts,batt  1 yr old
Should add my boot lid not latched leaving two int lights on
   that may have helped
