Jack Lift points
Posted: Mon Feb 25, 2019 3:19 pm
by JONM50D
Hello can someone confirm the front jack lifting point on my M50D, is it the circle in-between the 2 x holes as in image?
Many Thanks,
Front Jacking Point F15 M50D.jpg (37.07 KiB) Viewed 28174 times
Re: Jack Lift points
Posted: Mon Feb 25, 2019 3:57 pm
by gmc15
The jacking point for each side is just behind each front wheel and looks like this
https://xdrivers.co.uk/forum/download/f ... iew&id=553
Posted: Mon Feb 25, 2019 6:58 pm
by JONM50D
Thanks, I am aware if these, but wish to jack the whole front end up in one go. I beleive there is a front end single jacking point.
Posted: Mon Feb 25, 2019 9:26 pm
From what HenryM3 found (on your other thread about same) it is in the middle of the rectangular area just beyond the circular depression in your image. If you have a circular hard rubber (or similar) pad you can put between the car and jack (safely) that should help.
Posted: Wed Feb 27, 2019 9:58 am
by JONM50D
Many thanks found it, and jacked up car with no problems.
