Rubbing noise power loss
littlelordfonts
Post by littlelordfonts » Sun Feb 24, 2019 8:45 pm
Got these daily codes and after start up seems to. E a loss of power, rubbing noise for a few seconds then all good. No light come on and doesn’t do it every time any ides?
Official
Carly Diagnostics Report
X3 (E83), Build Year 2006
categorized as SUV / SAV was diagnosed with Carly on
Feb 23 2019
Carly found 13 control units. 8 fault codes were detected.
Motor Control
Engine / Motor
ECU OK, no Fault Code
Feb 23 2019 - X3 (E83), Build Year 2006 1/5
ABS / DSC / Brake
Dynamische Stabilitaets Kontrolle / DSC
Fault Code: 005F3A
Fault Explanation: :Distribution transmission ECU: clutch is in the open position - rear-wheel drive! / Distribution transmission ECU: VG- Fault - clutch is in the open position - rear-wheel drive! / Distributor transmission ECU: VG Error - clutch is in the open position - rear drive
VG clutch defective - clutch is in the open position - rear-wheel drive! / Distribution transmission ECU: VG - clutch is in the open position - rear-wheel drive!
Fault Code: 005F1E
Fault Explanation: :Variant code: TOL disabled via EEPROM / disabled trailer stabilization logic about EEPROM: info entry: Variant coding. / by followers Stability Control (ASL) encoding / EEPROM disabled --- (DSC: Steuergeraet variant coding) / disabled trailer roll logic about EEPROM: variant coding: Info entry. / Speed sensor front right air gap too big / internal control unit: missing DTC ID: M3
Airbag
Airbag
Feb 23 2019 - X3 (E83), Build Year 2006 2/5
Transmission Control
Transmission / Verteilergetriebe
Fault Code: 005208
Fault Explanation: :Servomotor wiring Fault Code: 0052D1
Fault Explanation: :incremental supply Fault Code: 0054C6
Fault Explanation: :Oelverschleiss
Instrumentation
Light/Rain Control
Instrument cluster / Kombiinstrument
Light / Licht
Feb 23 2019 - X3 (E83), Build Year 2006 3/5
Heating / AC
Aircondition / Klimaanlage
Fault Code: 000019
Fault Explanation: :Info compressor clutch / DME-AC / Blower control voltage / ADDITIONAL WATER PUMP / Heater wake-up line / relay Spritzduesenheizung / AUC heating
Park distance control / PDC
Sunroof / Roof
Park Distance Control / PDC
Sunroof / Schiebedach
Feb 23 2019 - X3 (E83), Build Year 2006 4/5
Audio / Navigation / Communication
Central info display / Zentrales Infodisplay
Navigation
Systems
Gateway /ZKE
Fault Code: 000055
Fault Explanation: :Passenger-side mirror: interruption motor folding / Adhesive relay signal MTS by mass in GM III / 54L: Left brake light short circuit
Fault Code: 00005F
Fault Explanation: :Driver Mirror: potentiometer axis 2/4 / 58VR / 58IVR / 58IHR: parking light front right or side marker light, front right or side marker light right rear short
Body
Elektronische Fahrzeug-Immobilisierung
Feb 23 2019 - X3 (E83), Build Year 2006 5/5
