E53 AIR FILTER
X5Andym
E53 AIR FILTER
Post by X5Andym » Sat Feb 23, 2019 4:43 pm
I am thinks of fitting a performance Ramair air filter to my E53 4.4 petrol, has any one done the same, is it worth doing or not.. read a bit about it.. still open to advice please..
Thank you very much
cheers
Andy
lezmtaylor
Re: E53 AIR FILTER
Post by lezmtaylor » Sat Feb 23, 2019 7:27 pm
I fitted a K&N oil charged filter to my 2002 4.4 (with lpg) in 2007, recharged it once, it seems to do the job ok.
Lez
dazzasgotav8
Re: E53 AIR FILTER
Post by dazzasgotav8 » Sat Feb 23, 2019 8:27 pm
are we talking about a performance panel filter to replace original or a cone style filter to replace the original box
lezmtaylor
Re: E53 AIR FILTER
Post by lezmtaylor » Sat Feb 23, 2019 8:37 pm
It fits in original filter casing.
Lez
X5Andym
Re: E53 AIR FILTER
Post by X5Andym » Sun Feb 24, 2019 9:25 am
[quote=dazzasgotav8 post_id=169176 time=1550953622 user_id=6156]
[/quote
A panel foam filter similar to a K & N..
Andy
dazzasgotav8
Re: E53 AIR FILTER
Post by dazzasgotav8 » Sun Feb 24, 2019 1:49 pm
over the years with messing around with filters i have settled for just buying a good quality paper one now, for my x5 i use nothing but mann filters which is what bmw use anyway and always buy them using the mann part number rather than for a specific vehicle as then you avoid the good ole bmw mark up factor ..
Re: E53 AIR FILTER
Post by henrym3 » Sun Feb 24, 2019 3:08 pm
Had this fitted for 3 years now,
staffordcox
Contact:
Re: E53 AIR FILTER
Post by staffordcox » Fri Mar 01, 2019 8:11 pm
That looks awesome!! Does it improve the sound too?
Re: E53 AIR FILTER
Post by henrym3 » Fri Mar 01, 2019 9:17 pm
It sounds pretty normal in day to day driving, but when you put your foot down everybody knows you have. I have kept the normal pipe that takes the outside air to the standard airbox and it now puts outside air into the area that the CAI draws in.
There’s lots of debate about drawing hotter/cold air in and I monitored air intake temperatures at the AFM before and after conversion. After 20mph the temperatures were the same and below 20mph and idling/traffic jams the temperatures were 2/3 degrees hotter.
