Hi guys
New to the forum as have just purchased a 2008 X5 E70 M-Sport
I have a problem with the passenger front door not opening, either from outside or inside.
Was fine when i bought the car (private sale)
I noticed when i was messing about with the settings in the computer that autolock was not on so i enabled it, not been able to open the door since.
I tried disabling autolock and numerous presses on the remote but no joy
Is this a common problem???
Any suggestions would be greatly appreciated.
Mark
Passenger Door Wont Open
Re: Passenger Door Wont Open
If you think it's the settings then you could disconnect the battery for 30 minutes and let it all reset.
Skid1963
Thanks for replying, i did change the autolock function to off in the settings, i think the actuator is not getting enough of a push to open the lock, managed to open it once on the key but is now stuck locked againAlan Gunn wrote: Thu Feb 21, 2019 6:43 pm If you think it's the settings then you could disconnect the battery for 30 minutes and let it all reset.
