So it's all new to me ,this x5 lark and I'm after few bit of gen ref , rear prop shaft, I need to know will gearbox get upset if I remove the rear prop to move the car ,as at mo she's stuck and I need to recover it. Want to unbolt the rwd prop and drive it fwd only! Is this possible to get it home. Thanks in advance for any info.
Cheers Mark.
E70 Can I run it with rear prop removed?
Fula28
Re: E70 Can I run it with rear prop removed?
I don't think the car will drive with the prop-shaft removed.
