Headlamp washer jets
Posted: Tue Jan 29, 2019 7:54 pm
by Wesley1874
One of my headlamp washer jets wont retract. How much of a job are they to remove and either repair or replace? Has anybody else had this problem? Thanks
Re: Headlamp washer jets
Posted: Tue Jan 29, 2019 10:33 pm
by Leslie
Noticed one of mine was sitting out so pushed it back in and but a stronger screenwash in and seems ok so far .I guess they get used more in the winter due to less hrs of daylight but only work once very so many window washes so it possible some hardly get used at all and can gum up and stick .
Posted: Wed Jan 30, 2019 7:53 am
by Gonkface
There is a pretty strong internal spring that is supposed to pull the nozzle back in. If yours is failing to retract then it could mean the spring has lost its tension. I replaced the passenger headlight washer jet last weekend. You can get one for less than £20 on eBay. It's quite an easy job if you are at all competent with a bit of diy. Loads of videos on YouTube.
Posted: Thu Jan 31, 2019 4:48 pm
by marti
Gonkface wrote: ↑Wed Jan 30, 2019 7:53 am
Hi, do you happen to have the bay item number for the one you purchased please, ones I've seen are really expensive....thanks
Posted: Thu Jan 31, 2019 5:12 pm
by Gonkface
Sure, here you go.
362423558488
Happy to help.
Posted: Sat Feb 02, 2019 11:04 am
by marti
Great, thank you very much
![Smile :)](./images/smilies/original.gif)
Posted: Mon Apr 08, 2019 10:50 am
by martins8585
Hi - I had a similar intermittent issue with mine which was fixed by pulling the jets out by hand and giving a good squirt of WD40.
Posted: Fri Jun 21, 2019 10:57 am
by Dave29
thanks - helpful - mine does that...now fixed
