oil temperature sensor?
- Loperamide
can anyone tell me where this is located on a 2003 4.4i ?
- henrym3
Re: oil temperature sensor?
Not aware of an oil temp’ sender, just pressure. Of course could be wrong.
IanP
Is the oil level sensor not combined with the oil temp sensor?.
This should be at the front of the lower oil pain i think.
- henrym3
It’s not listed as a temperature sensor in the parts, just oil level
- henrym3
There must be one somewhere, I was playing with the hidden menu today and it tells you the oil temperature,
The only place I can find it It mentioned in the TIS is that appears to be combined with the oil pressure sensor as an all in one.
IanP
https://www.e90post.com/forums/attachme ... 1273973836
I know it's from an e90 but i had thought the sensors were common
- henrym3
ome / BMW E53 X5 4.6is SAV /
Search documents:
Installation Location (EBO) B6238, X6238
Installation position B6238, X6238 front left of engine B6238 Oil temperature sensor X6238 Component connector (2-pin, black), Oil temperature sensor ...
Wiring Diagram (SSP) Engine oil temperature sensor
Engine oil temperature sensor X60003 28 X6238 2 X6238 1 X60003 27 . A6000 DME control unit GR/BR 0.5 M_TOEL RT/BL 0.5 A_TOEL . B6238 Oil temperature sensor . A6000 DME control unit 15 31 ...
Been out and searched round that area and can’t find any 2 pin connector that I can’t account for
Search documents:
