Valley pan gasket?
weirdfish
Valley pan gasket?
If you were taking the trouble to replace the gasket, and, or, o-rings in the pipes, ( water leak ), what else would you sort out or replace whilst you had it all apart.
IanP
Re: Valley pan gasket?
All of the hard to access small water pipes at the rear of the engine.
weirdfish
OK, what sort of costs are we looking at then, gaskets pipes o-rings etc etc
Are these all main dealer genuine bmw parts or would aftermarket parts be as good
Time wise, how long should this take, approximately of course
- sleepyfolk
Oil separator and all the pipes, yet another winter job for when I do the rocker cover gaskets, timing cover seals and plugs etc etc
