After my car has warmed up it occasionally judders while going uphill.
Also the rev counters bounces around about the 40-50mph speed.
What could be causing this?
2003 4.4i
uphill judders
- henrym3
Re: uphill judders
My money would be on the TC. Check the gb oil level and temperature.
IanP
Re: uphill judders
TC lockup? As above easiset thing to do first is check the oil kevels
- henrym3
Re: uphill judders
Make sure you or whoever is doing it use the correct procedures and the oil is at the right temperature
Re: uphill judders
When i had a similar problem on my 320d i confirmed it by using some of this.
The box was very smooth after adding it so i went ahead and had the torque converter changed.
https://www.ebay.co.uk/itm/2-TWO-Tubes- ... 1438.l2649
or
https://www.ebay.co.uk/itm/LUCAS-STOP-S ... 1438.l2649
or
