Heater Control panel not working when cold outside
Beardy1406
Post by Beardy1406 » Tue Nov 20, 2018 8:57 am
I have a weird problem which I have been researching with little joy. The heater control panel stays blank when turning on, however after 5 minutes it starts blinking and doing all sorts ( usually full cold full fan) before settling down and then working fine. No battery drain, no working when off ( to my knowledge). Gets a lot worse when the ambient temp is low outside.. have changed the fsr, no different... any thoughts before I get a replacement control panel? Thanks!!!
Re: Heater Control panel not working when cold outside
Post by henrym3 » Tue Nov 20, 2018 5:39 pm
Had more or less the same symptoms did the same thing, changed FSR. Replacement control panel sorted everything. Like me you now have a spare FSR. Pity there’s no one out there that can repair the control panel.
Beardy1406
Post by Beardy1406 » Thu Nov 22, 2018 9:02 am
Ha.. agreed would be awesome! Will source one and get at it.. will be ok if off diesel not petrol? Coding does not seem to be an issue if same fuel type but just checking! Thanks for your help, much obliged as getting dangerous when cannot clear windows!
Post by henrym3 » Thu Nov 22, 2018 7:02 pm
Can’t really answer as you haven’t listed your vehicle but if pre facelift then the same panel is listed for petrol and diesel.
