Brake Lines
- henrym3
Brake Lines
Subframe is out, have replaced lines to just in front of rear left wheel. Looking at the line under subframe I feel like I just saved my own life. Decided to bleed the brakes before fitting subframe and suspension. Used a one man bleed kit I’ve had for ever, took longer to get all the kit out than it did to bleed. Done it that way cos you just know that if you fit the subframe the joint underneath it will leak. I think it’s called "Sod’s law"
- sleepyfolk
Re: Brake Lines
Dodged a bullet on mine as well Henry, some of the hidden bits of steel pipe were really corroded, quite scary when you uncover it all!
Re: Brake Lines
Always better to find rusty brake pipes before the pedal sinks at the wrong moment when you need it .
Re: Brake Lines
I was to late.
The steel part of the rear flexi burst on the test but a good place to burst.
