Low down torque of 4.0d
AdamsX5
I’m getting used to driving the X5 now I’ve had it for 2 weeks I’ve only driven it a few times due to having insurance put on and making sure the service is done and all is ok.
Anyway I find there is a lot of low down torque or turbo at low speeds. I normally drive a 6 cylinder 3.0d F10 which basically cruises up to speed and I don’t notice the grunt at all. It’s as though the X5 needs the 2000 plus revs and low down turbo to get it going. I have driven another 4.0d but never paid attention to this at the time at the test drive.
Is this what you guys find? I’m not complaining as I like to make fast progress but sometimes you want to just slowly speed up from standstill and not have to experience too much turbo at low speeds.
Re: Low down torque of 4.0d
Not noticed it on mine but I use light throttle and feed it when I need it. It doesn’t take much to get it shifting though. The speed limit can go past embarrassingly quickly sometimes!
Has yours been remapped by any chance?
Digidick
Would it not be the smaller turbo helping out?
I’ve just come from a 530d F10 to my now remapped 40d and it does shift nicely from lower revs.
AdamsX5
How can I find out? Dealer wouldn’t tell me anyway.
Someone suggested a reset on Carly. Maybe previous owner was a sportier driver than me and it hangs on to low gears more.if that’s case it probably learn my style soon.
AdamsX5
[quote="Digidick"]
Did you find that your F10 got to speed with less noise and turbo and only got torque when you actually floored it. But with the 4.0d I find it’s needs to have that torque to get off.
I’m driving both on a daily basis back to back and it just seems weird.
I love the handling of the X5, the sitting position( feel like sitting on the floor with the F10) once you been out in the X5.
The mpg is around 25 cf to 32 with F10 a I do lots of short runs.
Did a once week motorway blast today to get dpf reg to 12g soot mass. Was 42g yesterday.
My F10 is crying out for a regen as it not had it weekly stroll on the motorway.
AdamsX5
I’ll see if I can do an audio file or a video. Maybe it’s just me getting used to it.
Digidick
Yeah it does seem to take more effort to get moving but you do know you’re driving a big lump and it amazes me how quickly it gets going and up to high speed.
Had some duel carriage way fun last week with an Impreza who couldn’t shake me off. Obviously I don’t know what he had under the bonnet apart from a turbo but I kept on his arse (at a safe distance) every time the traffic cleared and off we went.
AdamsX5
[quote="Digidick"]
I know what your saying with it being a big car and that. But it’s faster than my 5er as the 0-60 is 6.6s compared to around 7s for mine(525d) but the 5er feels faster somehow. I can’t put a finger on it.. seems weird...
OnlineLeslie
I notice mine is keen (sd but similar engine to 40d ) to hold the revs above 2k going up a hill but otherwise it changes up at 2k or less on a light throttle and a slight lift of when in 5th has it in 6th gear when it would otherwise just hold onto 5th. I suspect it holds gears longer if trying to do a regen
When i go from my x5 to my 320d that seems faster less effort but i put it down to being lower to the ground
- XP3NNY
[quote="AdamsX5"]
That's exactly what I'm experiencing with my 40d. Would be interested to compare couple of cars with the same engine. I test drove several 35d and 30d and haven't noticed this. I have to change the glow plug controller and somehow I though it might be related (not sure how tho).
BMW X5 40D SE // 2010
AdamsX5
[quote="XP3NNY"]
[quote="AdamsX5"]
Yep I have the glow plug error too.
But I thought that has something to do with warming up and ignitions
[quote="AdamsX5"]
- XP3NNY
How strange. What error you have on the glow plug?
AdamsX5
[quote="XP3NNY"]
1046a I think I can double check later from Carly report.
The report
Fault Report - Carly for BMW - Version: 27.80 FV
ID1: 44e7c656-0a04-4c8a-8b00-9a7c792f19f8-858
ID2: 2a8d1ae5-47c3-4591-8c40-a679fddbfdc9-cf6-c826e04eab972
INFO: 050DE3D7B9ACA68E766E60463E2A4
Base: E70
Build-Year: 2011
Faults: 1
ECUs: 21
Filter: just found
Model: X5 (E70) Automatic engine recognition (MotorID=53, Parameter=166) Battery: 14.5V
ADDITIONAL OBD: OFFNormal communication
Normal connection
normal
B2
Date: 2018-10-10 15:37:23
Carly Adapter
Version: 23
Device: >samsung< >chagallwifixx< >SM-T800<
Motor Control:
Engine / Motor
LIN bus communication Code: 0049A6
ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung
ECU not present/no response from ECU
Dynamische Stabilitaets Kontrolle / DSC
ECU OK, no Fault Code
Hand brake / Feststellbremse (EMF)
Airbag:
Advanced Crash and Safety Management (ACSM)
Transmission Control:
Transmission / Getriebe GS 19
Transmission / Getriebesteuerung
Instrument cluster:
Instrument cluster / Kombiinstrument
Central info display / Zentrales Display
Head-Up Display
Light/Rain Control:
Rain/light sensor / Regen-Lichtsensor RLS
High-beam / Fernlichtassistent
Heating / AC:
Air conditioning / Klimaanlage
AC front / Front Klimaanlage
Immobilizer System:
CAS
Park distance control:
Park Distance Control / PDC
Sunroof / Roof:
Roof / Dach
Audio/Navi/Communication:
Multimedia-Changer / Wechsler
Phone / Telefon
HiFi-Verstaerker
Tuner Antenna / Antenne
Hybrid Radio USA
Digital Satellite-Tuner USA
Car Communication Computer CCC
MASK
Rear-Monitor / Rueckfahrkamera
Headphones / Kopfhoerer Schnittstelle
Navigation
CD-Changer / Wechsler
Audio-System
Video
DAB
Seats:
Backrest width / Lehnenbreiteverstellung
Seats / Sitze
Seats / Sitze
Seats / Sitze
Seats / Sitze
Systems:
Junction Box Passenger / Beifahrer
Fuel pump / Kraftstoffpumpe
Tire pressure control / Reifendruck Kontrolle
Passive Go System
Car Communication
Anti-theft alarm system:
Theft alarm / Diebstahl Warnanlage
Chassis:
Längsdynamikmanager E7
Air suspension / Luftfederung
Electronic damper / Elektronische Daempfer
Body:
Automatisches Front Steering
Trailer / Anhaenger
Fussraummodul /FRM
EDC left front / vorne links
EDC right front / vorne rechts
EDC left rear / hinten links
EDC right rear / hinten rechts
Other:
The report
Base: E70
Build-Year: 2011
Faults: 1
ECUs: 21
Filter: just found
Normal connection
normal
B2
Carly Adapter
Version: 23
Motor Control:
Engine / Motor
ABS / DSC / Brake:
Airbag:
Instrument cluster:
Head-Up Display
Light/Rain Control:
Heating / AC:
Immobilizer System:
CAS
Sunroof / Roof:
Roof / Dach
Phone / Telefon
HiFi-Verstaerker
Hybrid Radio USA
MASK
Navigation
Audio-System
Video
DAB
Seats:
Seats / Sitze
Seats / Sitze
Seats / Sitze
Seats / Sitze
Systems:
Passive Go System
Car Communication
Chassis:
Body:
Trailer / Anhaenger
Fussraummodul /FRM
Other:
AdamsX5
Lin bus comm error as above report
