Page 1 of 2
Dipstick
Posted: Tue Oct 23, 2018 5:56 pm
by henrym3
While fiddling underneath I’ve found two oil leaks, easy fix on power steering one but has anyone changed the "o" ring seal on dipstick without major surgery to get to it.
Re: Dipstick
Posted: Tue Oct 23, 2018 6:20 pm
by marti
Should be pretty straight forward, the dipstick has a bracket bolted to the intake manifold, then you just pull it out and change the 'O' ring.....put it back in and give it a tap to make sure its home.
Re: Dipstick
Posted: Tue Oct 23, 2018 6:21 pm
Have a look on newtis dot info as it may have the instructions for the job
Re: Dipstick
Posted: Tue Oct 23, 2018 7:23 pm
by henrym3
Unfortunately it has ”U" piece bolted at the bottom of the dipstick to hold it in place and I can’t get at the screw. If I had another joint between my elbow and wrist I might just manage to get it undone?
Re: Dipstick
Posted: Tue Oct 23, 2018 8:11 pm
by marti
[quote="henrym3"]
From the underneath job then...they dont make it easy...do they!
Re: Dipstick
Posted: Wed Oct 24, 2018 11:24 am
by henrym3
The dipstick fix will be easy now, having dropped the sump I find it has a fair amount of plastic bits >:( so job has grown somewhat.
Re: Dipstick
Posted: Sun Oct 28, 2018 3:24 pm
by henrym3
With the sump off and looking up at the bottom of the engine (as you do) I notice that there is a piece of plastic stuck in the suction pipe intake grill. So remove suction pipe for closer inspection
There must be some serious suction to bend that grill and allow that plastic in and lodge. New suction pipe I think.
Re: Dipstick
Posted: Sun Oct 28, 2018 5:22 pm
by henrym3
Seeing as I decided to get a new suction pipe I thought I’d take the old to bits. Didn’t expect this.
Re: Dipstick
Posted: Sun Oct 28, 2018 5:31 pm
by IanP
If the bits are a sort of tan colour, I would be checking my cam chain blades
Re: Dipstick
Posted: Sun Oct 28, 2018 5:32 pm
I was just thinking the same. That colour plastic and a V8 engine is not a good sign.
Re: Dipstick
Posted: Sun Oct 28, 2018 5:42 pm
by henrym3
Parts are on order, strip is underway.
Re: Dipstick
Posted: Sun Oct 28, 2018 6:07 pm
Thank goodness the suction pipe filter did its job. That could have been scary, and all because of a leaking dipstick. Someone up there cares
Re: Dipstick
Posted: Sun Oct 28, 2018 9:02 pm
by henrym3
God loves a V8
Re: Dipstick
Posted: Sun Oct 28, 2018 9:51 pm
by dazzasgotav8
should us v8 owners be thinking about dropping the sumps ??????????
Re: Dipstick
Posted: Mon Oct 29, 2018 8:06 am
by Greydog
30k since my engine rebuild and still I get an uneasy feeling about those damn plastic guides. Even though I fitted a pre-oiler system to ensure full oil pressure before engine start to try and help them.
When they stripped the engine the strainer was 80% clogged with sludge and pieces of guide which we believe caused the pump to fail. Looks like you have some work on your hands, good luck hope there is no more surprises.
