Dipstick
Dipstick
Post by henrym3 » Tue Oct 23, 2018 5:56 pm
While fiddling underneath I’ve found two oil leaks, easy fix on power steering one but has anyone changed the "o" ring seal on dipstick without major surgery to get to it.
VW R32 Gone
Re: Dipstick
Post by marti » Tue Oct 23, 2018 6:20 pm
Should be pretty straight forward, the dipstick has a bracket bolted to the intake manifold, then  you just pull it out and change the 'O' ring.....put it back in and give it a tap to make sure its home.
Re: Dipstick
Post by X5Sport » Tue Oct 23, 2018 6:21 pm
Have a look on newtis dot info as it may have the instructions for the job  :)
Re: Dipstick
Post by henrym3 » Tue Oct 23, 2018 7:23 pm
Unfortunately it has ”U" piece bolted at the bottom of the dipstick to hold it in place and I can’t get at the screw. If I had another joint between my elbow and wrist I might just manage to get it undone?
VW R32 Gone
Re: Dipstick
Post by marti » Tue Oct 23, 2018 8:11 pm
[quote="henrym3"]
From the underneath job then...they dont make it easy...do they!
Re: Dipstick
Post by henrym3 » Wed Oct 24, 2018 11:24 am
The dipstick fix will be easy now, having dropped the sump I find it has a fair amount of plastic bits >:( so job has grown somewhat.
VW R32 Gone
Re: Dipstick
Post by henrym3 » Sun Oct 28, 2018 3:24 pm
With the sump off and looking up at the bottom of the engine (as you do) I notice that there is a piece of plastic stuck in the suction pipe intake grill. So remove suction pipe for closer inspectionImage
There must be some serious suction to bend that grill and allow that plastic in and lodge. New suction pipe I think.
VW R32 Gone
Re: Dipstick
Post by henrym3 » Sun Oct 28, 2018 5:22 pm
Seeing as I decided to get a new suction pipe I thought I’d take the old to bits. Didn’t expect this.
VW R32 Gone
IanP
Re: Dipstick
Post by IanP » Sun Oct 28, 2018 5:31 pm
If the bits are a sort of tan colour,  I would be checking my cam chain blades
Re: Dipstick
Post by X5Sport » Sun Oct 28, 2018 5:32 pm
I was just thinking the same.  That colour plastic and a V8 engine is not a good sign.
Re: Dipstick
Post by henrym3 » Sun Oct 28, 2018 5:42 pm
Parts are on order, strip is underway.
VW R32 Gone
Re: Dipstick
Post by X5Sport » Sun Oct 28, 2018 6:07 pm
Thank goodness the suction pipe filter did its job.  That could have been scary, and all because of a leaking dipstick.  Someone up there cares  :)
Re: Dipstick
Post by henrym3 » Sun Oct 28, 2018 9:02 pm
God loves a V8 :)
VW R32 Gone
dazzasgotav8
Re: Dipstick
Post by dazzasgotav8 » Sun Oct 28, 2018 9:51 pm
should us v8 owners be thinking about dropping the sumps ??????????
Greydog
Re: Dipstick
Post by Greydog » Mon Oct 29, 2018 8:06 am
30k since my engine rebuild and still I get an uneasy feeling about those damn plastic guides. Even though I fitted a pre-oiler system to ensure full oil pressure before engine start to try and help them.
When they stripped the engine the strainer was 80% clogged with sludge and pieces of guide which we believe caused the pump to fail. Looks like you have some work on your hands, good luck hope there is no more surprises.
