Sas calibration code
Zedhed
Post by Zedhed » Sat Oct 13, 2018 9:23 am
Hi folks,as i cant calibrate the sas manually,dis57 has asked for a code to be entered electronically,so where do i find this code.
Re: Sas calibration code
Post by marti » Sat Oct 13, 2018 10:59 am
Found this, you need to run SSS to encode:
Now all you need to do is to encode the sensor. Before you encode the new sensor, remember to run DIS to clear all fault code first, then use SSS to encode it. You must remain the key in position 2 when using DIS to clear all the fault code, then keep the key in position 2, run SSS to encode the sensor and then calibrate the sensor. Remember do not start the engine or do anything that make the vehicle generate any fault after clearing all the fault code, otherwise encoding task will fail. If you do not have a battery charger to keep the voltage at 13V or higher, you can run the engine through out all the DIS and SSS job. Then you are all done with it.
Zedhed
Post by Zedhed » Sat Oct 13, 2018 2:35 pm
Ok thanks bud.
