Hi all
As winter is approaching thinking of getting a set of winter wheels. What is the smallest size I can go to and what tyre size is recommended?
Many thanks
Smallest size wheels for 3.0sd
b21playa
F10 M5 Competition
E70 X5 sd MSport
E90 330i MSport
E70 X5 sd MSport
E90 330i MSport
Re: Smallest size wheels for 3.0sd
Have a look at Realoem, use the last 7 of your VIN to pull up your model and see what’s available. Probably 18” or 19”. The tyre pressure plate should also tell you what wheel sizes can be used with correct tyre sizes as the plate lists all OEM supported fitments.
b21playa
Looking at spare wheel size listed which is 18”, I’m guessing that’s the smallest
F10 M5 Competition
E70 X5 sd MSport
E90 330i MSport
E70 X5 sd MSport
E90 330i MSport
